1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: A VME-MXI problem in the KEKB control system.
To: [email protected]
Cc: EPICS-tech-talk <[email protected]>, Tadahiko Katoh <[email protected]>, Akiyama <[email protected]>
Date: Fri, 07 Sep 2001 09:56:33 -0500
Noboru Yamamoto wrote:
> Ever since the KEKB accelerators became operational, the VME/MXI/VXI
> connection has been a  problem. Recently Mr. Akiyama of our group
> studied the problem carefully and identified the source of problem.
> After the discussion with National Instrument, the maker of VME-MXI
> interface board, we applied a modification to the VME-MXI board
> following the suggestion by NI.
This was interesting.  I would like to add that APS has experienced a
different problem when trying to use a VME-MXI-1 card with a PowerPC CPU.
Our symptoms cannot be explained by a glitch on the DTACK line as
described, and we do not experience lock-up of the VMEbus in the way that
KEKB have, therefore ours is definitely a different problem with the
VME-MXI-1 module.
Our experience with an MVME2700 was a problem reading some of the VXIbus
configuration registers.  When using a PowerPC the bits on the lowest 4
data lines D0-D3 were not reliably read, although an MVME167 in the same
crate showed the registers to be completely stable.  This only affected a
very few registers, the most important being the VXIbus Status Register
VSR, which has a self-test Pass/Fail bit in bit 2.  By telling the VXI
Resource Manager to ignore the value returned in this bit we are able to
use a VXI-MXI-1 board with an MVME2700, although we haven't done extensive
testing of this configuration.
We have not contacted National Instruments about this, and will probably
replace our VME-MXI-1 boards with VME-MXI-2 as we come to install PowerPC
CPU boards as the older VME-MXI-1 module is now obsolete.  I would be
interested to hear whether KEKB have seen the problem I described above,
and if so did you make any changes to the drvEpvxi.c VXI Resource Manager
to avoid it or are you using a different Resource Manager anyway.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
A VME-MXI problem in the KEKB control system. Noboru Yamamoto
Prev: A VME-MXI problem in the KEKB control system. Noboru Yamamoto
Next: undefined symbol: _rsrvCheckPut Graham Waters
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
