Jeff Hill wrote:
> Rolph,
> > What solutions are currently used in the community for image capture. We
> > want to look at beam spots on scintillators with a camera and integrate
> > capture and maybe processing into the control system.
> On a related note, I have finished a CA protocol upgrade that includes
> a configurable maximum array size limit. This will show up in the next
> R3.14 release.
> Jeff
When you consider to extend CA libarary to support large array, please also
consider to add API/protocol to access subarray with offset.
As far as I understand, EPICS CA/DB library allow to access a part of
array if it starts
from the top of array, ie. a[:n] in Python notation.. In Db library, we
needed to implement
API to access array data with offset, i.e. a[n:n+m] in Python notation
again, for effcient use
of memory in a subarray record. I believe this kind of access method
is useful for many applications and it will not so difficult and will
not break any existing application.
I would greatly appriciate if you could consider this possibility.
Thank you,
Noboru Yamamoto
KEKB control group
KEK, JAPAN
- RE: Image capture Jeff Hill
Re: alarm handler confusion (and solution) Janet Anderson
<2001>
<2001>
