1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: AllenBradley PLC via ethernet
To: [email protected], [email protected]
Cc: [email protected]
Date: Wed, 29 Aug 2001 15:49:51 -0600
At 03:29 PM 8/29/2001, Brian McAllister wrote:
>Is anyone working on EPICS support for AllenBradley PLCs over ethernet
>(specifically the MicroLogix 1500) ?
Yes, but not ML1500:
For SNS, we are looking at the A-B ControlLogix PLC,
accessed via Ethernet.
It's using the "EtherNet/IP" (Industrial Protocol),
a TCP-encapsulation of ControlNet/CIP
together with A-B specific extensions for accessing
the tags (variables) of the ControlLogix PLC.
I don't know if this will help you with the ML1500,
I'm pretty sure that it won't work out of the box.
-Kay
AllenBradley PLC via ethernet Brian McAllister
Prev: AllenBradley PLC via ethernet Brian McAllister
Next: Weird file access problem with vxWorks Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
