Given that two IOCs need to talk with each other they could each "CA
client" just as your SUN workstation becomes a client.
Now you must define for the IOC the EPICS_CA_ADDR_LIST environment variable.
This could be done in the resource.def file as follows:
# add the following line
EPICS_CA_ADDR_LIST DBF_STRING <IP Address of the IOC you want to
talk to>
OR
you could add a putenv statement in your st.cmd file as follows:
putenv (" EPICS_CA_ADDR_LIST = <IP Address of the IOC you want to talk to>
Hope this helps.
Ernest L. Williams Jr.
SNS Control Systems Group, ORNL
701 Scarboro Rd., MS 6473
Oak Ridge, TN 37830
Phone 865-241-9071
e-mail: [email protected]
Fax 865-241-6739
----- Original Message -----
To: "EPICS Tech-Talk" <[email protected]>
Sent: Friday, August 24, 2001 12:41 PM
Subject: Problem talking CA across two CPUs in same crate???
> Hello,
> I am using EPICS R3.13.3 and I am using the sequencer. There are
> two Motorola PPC boards in my configuration. One of which has
> a sequencer within it (call it CPU1) and the other has PMAC
> motor control (call it CPU2). It appears that the sequencer
> works fine with recorders within CPU1. But for some reason
> the sequencer process variables that are associated with
> recorders in CPU2 cannot connect. Both CPUs are plugged into
> the same network also.
> Are there any ideas what could be wrong with my configuration.
> Oh yes I can get to all the process variables via the client
> Sun workstation using caget, caput and camonitor calls.
> All replies would be greatly appreciated.
> Len
> ____________________________________________________
> Leonard J. Reder
> Jet Propulsion Laboratory
> Interferometry Systems and Technology Section 383
> Email: [email protected]
> Phone (Voice): 818-354-3639
- Re: Problem talking CA across two CPUs in same crate??? Leonard J. Reder
- Problem talking CA across two CPUs in same crate??? Leonard J. Reder
RE: devNode, drvNode, drvSerial source? Porter, Rodney
<2001>
<2001>
