1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: devNode, drvNode, drvSerial source?
To: Steven Hartman <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 24 Aug 2001 10:32:21 -0600
Steve,
drvSerial is commonly used with drvAscii/devAscii layer that
supports a fairly generic command and response system. An up to date
version can be obtained from Allan Honey at Keck
([email protected]). drvSerial itself provides device
independent support for (named) serial devices.
The devNode/devNode package is a simple layer that uses drvSerial.
It is not nearly as robust as drvAscii/devAscii, although does
handle the case of multiple response delimiters, which drvAscii
does not. Unless you have a very strange device (like the legacy
control system we were talking to for the CFHT application)
I'd recommend use of drvAscii instead.
The tyGsOctal software does not _require_ use of drvNode, or even
drvSerial for that matter.
Steven Hartman wrote:
> Is source code for drvNode, devNode and drvSerial still available?
> I am looking into using Andrew Johnson's drvIpac with tyGSOctal for serial
> communication using SBS IP-OctualUART-232 modules mounted on a SBS VIPC616
> carrier board. It appears that this configuration will also require
> devNode and drvNode and maybe drvSerial?
> The links for devNode and drvNode
> (ftp://ftp.cfht.hawaii.edu/pub/tcs/epics/) are no longer valid.
> Thanks,
> Steve Hartman
> [email protected]
> Duke Free Electron Laser Laboratory
Aloha,
	Peregrine
Peregrine M. McGehee	[email protected]	(505) 667-3273
Spallation Neutron Source - Global Controls (SNS-4)
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
devNode, drvNode, drvSerial source? Steven Hartman
Prev: devNode, drvNode, drvSerial source? Steven Hartman
Next: mbbiDirect/mbboDirect - why only 16 bits ? Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: devNode, drvNode, drvSerial source? Porter, Rodney
