1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Apropos making fields configurable
To: Benjamin Franksen <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Thu, 09 Aug 2001 14:13:51 -0500
Benjamin Franksen wrote:
> Andrew Johnson wrote:
> > LINR might be converted to a string field, which would allow the desired
> > behaviour (and permit the addition of new breakpoint tables at run-time).
> > Another problem with the enum is that it really should be dynamic
> > according to the breakpoint tables actually loaded into the IOC, but it
> > isn't.  However switching to a string will probably break some existing
> > databases and displays, so I expect it to be rejected.
> I have thought about a different solution. Reduce menuConvert to a fixed
> set of general conversion methods, i.e. one of {NO CONVERSION, LINEAR,
> BREAKPOINT, SUBROUTINE}. A separate (new) field of string type could
> hold the name of the breakpoint table in case LINR is BREAKPOINT or the
> name of a subroutine in case LINR is SUBROUTINE.
This is probably better than just having a string field, but it's not
completely backwards compatible as a record definition must specify two
field values to select a particular breakpoint table.  It would also need
modifications to any displays that used to be able to switch between
different tables.
- Andrew
The world is such a cheerful place when viewed from upside-down
It makes a rise of every fall, a smile of every frown
Re: Apropos making fields configurable Benjamin Franksen
Re: Apropos making fields configurable Bob Dalesio
Re: Apropos making fields configurable Andrew Johnson
Prev: CapFast Linux version and update Dr. Chong Lee
Next: Re: Apropos making fields configurable Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Apropos making fields configurable Benjamin Franksen
