1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: DM/EDD and Redhat Linux
To: "Chestnut, Ronald P." <[email protected]>
Cc: "Tech-Talk (E-mail)" <[email protected]>
Date: Fri, 03 Aug 2001 13:27:14 -1000
Hi Ron,
First thing you might want to try is close nescape/gnome etc and start
with a very basic X session. If that still fails, it might depend on
your X server setup, version, and graphic card.
First I was using 16 depth with XFree_SVGA on a neomagic card and that
worked fine.
When I upgraded to rh7.1, the X server changed and I had the blink
problem, so I went back to the old SVGA.
I think if you Xstart in 8bit depth mode, things are more likely to
work, but that's quite a compromise. There's a hack to have two Xservers
running simultaneously and toggling between the two with ctrl+alt+F6/7 -
I haven't too much impressed by that.
cheers,
Mattieu
PS: edd/dm builds and runs on linux with openmotif (that won't really
help you! it's just for information if you plan to run things on Linux).
"Chestnut, Ronald P." wrote:
> We're just starting to look at Linux. One of the first things we've done is just set DISPLAY to the linux box and try the various tools from Solaris.
> StripTool, DM2K, GDCT work fine.
> Both DM and EDD fail to start, complaining that they can't allocate blinking colors. I haven't seen this before, even on other systems which don't display blinking colors.
> Is there some magic incantation involved here?
> Thanks.
> /Ron Chestnut
> "If you're one of those people who puts solar panels on your house or drives a battery powered car, you might as well vote for Gore"
> -- Dick Cheney  Oct. 3, 2000
Matthieu Bec              Gemini Observatory
Tel: +1 808 9742557       670 N. A'ohoku Place
Fax: +1 808 9359235       Hilo, Hawaii 96720, USA
DM/EDD and Redhat Linux Chestnut, Ronald P.
Prev: DM/EDD and Redhat Linux Chestnut, Ronald P.
Next: Antigen found =*.url file ANTIGEN_ATREUS
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: DM/EDD and Redhat Linux Ernest L. Williams Jr.
