1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: [Fwd: socket errors]
To: "Geoff Savage" <[email protected]>, <[email protected]>
Date: Tue, 31 Jul 2001 11:11:37 -0600
> Have any Win2000 users seen these errors?  Is there some way to
> eliminate them?
Geoff,
As soon as I get access to a windows 2000 machine I will look into
this. The warning messages are reported to be benign (if annoying).
Jeff
> Thanks
> Geoff
> > David Huffman wrote:
> > Hi Geoff
> > Is there a chance you will get around to looking at the socket error I
> > get on NT machines.
> > It is just very annoying.
> > Dave
> > This is the error message.
> > Unexpected UDP failure WIN32 Socket Library Error 10054
> > This is a reference I found about it.
> > WSAECONNRESET
> > (10054)
> > Connection reset by peer.
> > An existing connection was forcibly closed by the remote host. This
> > normally results if the peer application on the remote host is
> > suddenly stopped, the host is rebooted, or the remote host uses a hard
> > close (see setsockopt for more information on the SO_LINGER option on
> > the remote socket.) This error may also result if a connection was
> > broken due to keep-alive activity detecting a failure while one or
> > more operations are in progress. Operations that were in progress fail
> > with WSAENETRESET. Subsequent operations fail with WSAECONNRESET.
[Fwd: socket errors] Geoff Savage
Prev: Re: Error Message Dale L. Brewe
Next: Which EPICS Makefile variable should I use? J. Frederick Bartlett ([email protected])
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [Fwd: socket errors] matthias muntwiler
Next: CA connect delays under Windows Mark Rivers
