1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Archiver
To: tech talk <[email protected]>
Date: Mon, 30 Jul 2001 15:51:29 -0400 (EDT)
The archiver is not failing to receive events. My interpretation
of archive data was incorrect. It appears that when a PV disconnects
the archiver generates data but when the PV reconnects no data is
generated when the PV value did not change. This results in the
following:
07/23/2001 04:49:10.000000000   OFF     Repeat 19731
07/23/2001 04:49:15.009771252   ON
07/23/2001 15:13:40.000000000   ON      Repeat 3747
07/23/2001 15:13:48.706195000   -       Disconnected
07/23/2001 15:51:59.035355000   -       Disconnected
07/23/2001 15:55:48.541504844   ON
07/23/2001 16:39:00.000000000   ON      Repeat 260
07/23/2001 16:39:01.606623000   -       Disconnected
07/27/2001 13:20:06.997712000   -       Disconnected
07/27/2001 13:55:14.999999800   OFF     INVALID UDF
07/27/2001 20:06:40.000000000   OFF     Repeat 2229
07/27/2001 20:06:45.015774866   ON
07/27/2001 20:07:50.000000000   ON      Repeat 7
So, using the LibIO API, if I ask for data prior to 07/27/2001 13:20:06 I
may get a record which is again invalid. One therefore must keep going
back until a valid record is obtained.
I would argue for the generation of a data record when the PV reconnects.
John
On Mon, 30 Jul 2001, john sinclair wrote:
> We are using the following version of the Channel Archiver:
>   Version 1.6.3, built Apr  6 2001, 13:33:59
> The engine has been logging date since 6/8/01 and at some point in the
> last two weeks has stopped receiving events for a number of PVs.
> The IOC is running R3.13.1.
> The client was built with R3.13.3.
> Are there any known problems that can explain this behavior?
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362   865-574-1268 (fax)
John Sinclair
[email protected]
Channel Archiver john sinclair
Prev: Re: Error Message Paul Sichta
Next: VMIC 4145 Support Garrett D. Rinehart
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VxWorks kernel configuration for GPIB Andrew Johnson
