1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Making VAL configurable [was: Hex constant as input to longin record?]
To: EPICS Techtalk <[email protected]>
Date: Thu, 19 Jul 2001 00:13:07 +0200
Marty,
I prefer your solution; it is so simple, I ask myself why this wasn't
done when the link definition was changed so that "" != "0" (was that
3.13.1?).
> The bad effect is that users have two ways to define values for the VAL field,
> e.g. assign values to VAL itself or else assign values to the associated link
> field. Does this matter? Maybe not.
Definitely not. Anyway you'll have to have two ways if you want to be
backward compatible. Remember the solution for the linear conversion?
Something else: Some people might get different behavior with existing
databases because of VAL assignments which are now ignored. It should be
fairly easy, though, to run a simple (perl) script to detect such
assignments and throw them out if the default should be undefined value.
Anyway, each site can make this change by themselves.
Ben
Berliner Elektronenspeicherring-Gesellschaft für Synchrotronstrahlung
(BESSY) GmbH, Control System Group
Albert-Einstein-Straße 15, 12489 Berlin, +4930 6392 8462, www.bessy.de
Apropos making fields configurable Benjamin Franksen
RE: Hex constant as input to longin record? Redman, Russell O.
Re: Hex constant as input to longin record? Marty Kraimer
Prev: Re: Hex constant as input to longin record? Marty Kraimer
Next: Apropos making fields configurable Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
