1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Hex constant as input to longin record?
To: Werner Portmann <[email protected]>
Cc: EPICS tech talk <[email protected]>
Date: Wed, 18 Jul 2001 08:48:36 -0500
Werner Portmann wrote:
> Hi all
> this is not only true for the INP field of the longin record but for the
> DOL field of the longout record either. (We have Epics 3.13.2).
> Is it the true for all INP and DOL fields?
The following code decides if the link should be a constant. (dbPutString in
dbStaticLib.c)
                    /* Check first to see if string is a constant*/
                    /*It is a double if strtod eats entire string*/
                    /*leading and trailing blanks have already been stripped*/
                    tempval = strtod(pstr,&end);
                    if(*end == 0) {
Thus it does not accept hex constants. Note also that recGblInitConstantLink
uses sscanf to convert from a string
to a numeric value. Thus just changing the above code will not fix the problem.
A possible fix is to have the above code try both strtod and strtol and if
either is successful then make the link a constant.
If recGblInitConstantLink uses "%i" for sscanf it looks like it should work.
Unless something unforseen arises I will make the changes for the next release
of 3.13 and 3.14.
Marty Kraimer
Re: Hex constant as input to longin record? Werner Portmann
Prev: Re: Hex constant as input to longin record? Werner Portmann
Next: Initializing mbbo with a string value Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Hex constant as input to longin record? Redman, Russell O.
