1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: lingering ca connections on iocs
To: "Geoff Savage" <[email protected]>, <[email protected]>
Date: Mon, 9 Jul 2001 09:10:36 -0600
Geoff,
If you abruptly shutdown the client by turning off the workstation
then the TCP state machine will not sequence through its normal
exit protocol. This will leave resources allocated in the server
until the TCP keep alive sequence is initiated. It usually takes
about 30 default minutes for the TCP keep alive timer to expire,
but this will vary depending on the configuration of your IP kernel.
Jeff
> -----Original Message-----
> From: Geoff Savage [mailto:[email protected]]
> Sent: Friday, July 06, 2001 2:48 PM
> To: [email protected]
> Subject: lingering ca connections on iocs
> We have noticed that clients that don't exit gracefully retain their
> connections on the IOC.  We use the casr command on the IOC to see that
> although the client is dead the IOC still has resources allocated for
> it.  Should these rousources be freed after a period of time?
> Thanks
> Geoff
lingering ca connections on iocs Geoff Savage
Prev: Re: Channel Access under VxWorks (Power PC) Matthieu Bec
Next: Channel Access under VxWorks (Power PC) amaudruz
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: lingering ca connections on iocs Geoff Savage
Next: R3.14.0alpha2 john sinclair
