1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IOC Controllers Under Linux (or IOC's for < $500)
To: Eric Norum <[email protected]>
Cc: Bill Lavender <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 26 Jun 2001 23:29:10 -0500 (CDT)
On Tue, 26 Jun 2001, Eric Norum wrote:
> Bill Lavender wrote:
> > Can you send me a copy of the changes that you had to make to talk to the
> > Cyberresearch boards?  It would be useful to see some examples of what is
> > required to talk to real devices under Linux via ioccore.
> For simple I/O (no interrupts, no DMA) I've found it easiest to just use
> inb, outb, etc. right from the user level.  No kernel modules and no
> linux drivers required.  I start such applications from a setuid-root
> wrapper which allocates the appropriate I/O ports then setuid's back to
> the real uid and exec's the application.  In this way any user can
> safely play with the device without needing root priviliges.
Yep, that is what I am doing now.  Very simple using inb and outb.
The only real "issue" is the compile time -ansi -pedantic which
breaks the macros in /usr/include/asm/io.h, but I was lazy and just
wrote a simple wrapper library. for this.  Its cleaner in ioccore
since that app can run as root so an iopl(3) does it all.
- John
John Quintana                       Phone:630-252-0221
Northwestern University             FAX: 630-252-0226
DND-CAT                             email: [email protected]
APS/ANL Building 432/A008
9700 South Cass Avenue
Argonne, IL 60439
Re: IOC Controllers Under Linux (or IOC's for < $500) Eric Norum
Prev: 3.14 not 3.13 John Quintana
Next: serial port communication Weixing Cheng
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: IOC Controllers Under Linux (or IOC's for < $500) Eric Norum
Next: 3.14 not 3.13 John Quintana
