1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Bug in e2db
To: "'Benjamin Franksen'" <[email protected]>, EPICS Techtalk <[email protected]>
Date: Wed, 13 Jun 2001 15:45:59 -0700
Dear Benjamin,
Thanks for the kudos.
Yes, I have got the "Warning: Port property "typ(U0)" should not equal
"val"." message.  Once I realized that I could leave the type as val and get
a working database, I decided to ignore it.  I only fixed these bugs because
I desperately had to in order to meet a looming deadline.  Maybe next year I
will have time to look at these non-fatal problems, but not until then
unless they grow poisonous fangs and become fatal.  Ahhh, the joys of
collaborative software!
Cheers,
Russell O. Redman
-----Original Message-----
Sent: Wednesday, June 13, 2001 2:50 PM
To: EPICS Techtalk
Subject: Re: Bug in e2db
Redman, Russell O. wrote:
> There is a stylistic issue in that the for loop tests for the completion
of
> the loop using "flink != 0", instead of "flink != NULL".  Practically,
they
> are the same test but since pointers are (or should be) initialised to
NULL,
> they should also be tested against NULL.  This stylistic defect occurs in
a
> variety of places throughout the program.
Just a little side-remark: I got the impression people will NEVER EVER
agree wether to use 0 or NULL. Matter of style, as you said. [Personally
I like to use 0 (zero) because comparison reduces to logical test i.e.
if(p) instead of if(p != 0) which is redundant. AFAIK, C language
definition garuantees this to work as expected.]
You are right, however, that choice should be consistent, i.e.
initialization same as comparison.
Much more important: Good job done, debugging e2db!
While you're at it, have you ever got error message like following:
----  Loc: motor:slider
Warning: Port property "typ(U0)" should not equal "val".
Warning: Port property "val(U0)" does not exist, treating as field ref.
Always appears if you use a free port, assign it some record field and
connect the port to something.
Problem is when you fix it, it breaks. Meaning *with* error message
produces correct db, but if you chose "path" for port property you get
wrong result. Took me quite a while then, to find out what was wrong:
why, my links simple weren't there after I "fixed" it.
Ben
Re: Bug in e2db Benjamin Franksen
Prev: Re: Bug in e2db Benjamin Franksen
Next: Re: Bug in e2db Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
