Steven Hartman wrote:
> On Fri, 8 Jun 2001, J. Frederick Bartlett ([email protected]) wrote:
> > dbProcess. The question is: what do I put in the DTYP and INPUT fields
> > of the record when I define it in a .db file?
> If I understand correctly . . .
> record(ai,"foo") {
> field(DTYP,"Soft Channel")
> field(INP,"")
> where INP is a constant with no initial value.
> Steve Hartman
> [email protected]
> Duke Free Electron Laser Laboratory
This is a better answer than the one I gave. There is a difference between
field(INP,"")
and
field(INP,"0")
devAiSoft has the statements
static long init_record(pai)
struct aiRecord *pai;
/* ai.inp must be a CONSTANT or a PV_LINK or a DB_LINK or a CA_LINK*/
switch (pai->inp.type) {
case (CONSTANT) :
if(recGblInitConstantLink(&pai->inp,DBF_DOUBLE,&pai->val))
pai->udf = FALSE;
break;
Thus for field(INP,"") udf will not be set FALSE but for field(INP,"0") it will
be set false.
Marty Kraimer
- Re: Input records with no device support Steven Hartman
Re: Input records with no device support Marty Kraimer
Attaching other interface after VxWorks boot Vladis Korobov
<2001>
<2001>
