Hi Jeff,
>>> On Wed, 23 May 2001 15:54:29 CST, "Jeff Hill" <[email protected]> wrote;
> This particular ifdef was added to R3.13.4 so that it would be
> compatible with the SENS IP kernel present in Tornado II.
> #if ( defined (BSD) && ( BSD >= 44 ) ) || defined ( SOCKADDR_HAS_LEN )
> size = pifreq->ifr_addr.sa_len + sizeof(pifreq->ifr_name);
> if (size < sizeof(*pifreq))
> size = sizeof(*pifreq);
> #else
> Apparently, the condition "(BSD) && ( BSD >= 44 )" is true on your OS
> despite the fact that your OS does not, by default, expose an IP kernel
> interface that behaves like BSD 4.4?
Actually BSD on Tru64Unix (both V4.0F and V5.1) is 198911, which means
OSF1 was based on BSD 4.3 (?). Thus ( defined (BSD) && ( BSD >= 44 ) )
does not work. I did something like this, which is ugly.
*** osdNetIntf.c.org Fri Feb 16 09:21:11 2001
--- osdNetIntf.c Wed Apr 11 11:50:54 2001
*** 53,59 ****
unsigned int size;
! #if ( defined (BSD) && ( BSD >= 44 ) ) || defined ( SOCKADDR_HAS_LEN )
--- 53,62 ----
unsigned int size;
! /* #if ( defined (BSD) && ( BSD >= 44 ) ) || defined ( SOCKADDR_HAS_LEN ) */
! #if (( defined (BSD) && ( BSD >= 44 ) ) || defined ( SOCKADDR_HAS_LEN )) && !defined ( __osf__ )
! /* on osf1, BSD is 198911 */
Regards.
Kazuro FURUKAWA <[email protected]>
Linac, High Energy Accelerator Research Organization (KEK), Japan
- RE: Build failure for if_depen.c Jeff Hill
Error reporting from device support for output style records J. Frederick Bartlett ([email protected])
<2001>
<2001>
