1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: devVXStats and task crash
To: EPICS Questions <[email protected]>
Date: Mon, 30 Apr 2001 09:35:06 -0500
Marty Kraimer wrote:
> I have had some private message with Andy Foster about this problem. We are making
> changes to devVXStats to fix the problem. As soon as we have done some more
> testing I will make the new code available. Andy also reports that the new
> algorithm for computing cpu usage is more stable.
I am attaching the latest version that has been tested on both 68K and powerPC.
Marty Kraimer
/* devVXStats.c - Device Support Routines for vxWorks statistics */
 *      Original Author: Jim Kowalkowski
 *      Date:  2/1/96
 *	Current Author: Marty Kraimer
 *	Date: 18NOV1997
                          COPYRIGHT NOTIFICATION
(C)  COPYRIGHT 1993 UNIVERSITY OF CHICAGO
This software was developed under a United States Government license
described on the COPYRIGHT_UniversityOfChicago file included as part
of this distribution.
#include <vxWorks.h>
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <taskLib.h>
#include <wdLib.h>
#include <tickLib.h>
#include <sysLib.h>
#include <alarm.h>
#include <dbDefs.h>
#include <dbScan.h>
#include <dbAccess.h>
#include <callback.h>
#include <recSup.h>
#include <devSup.h>
#include <link.h>
#include <aiRecord.h>
#include <aoRecord.h>
	The following device definitions must exist
	device(ai,INST_IO,devAiVXStats,"VX stats")
	device(ao,INST_IO,devAoVXStats,"VX stats")
	sample db file to use all data available:
	Notive that the valid values for the parm field of the link
	information are:
	ai:
		memory       	- % memory used
		cpu             - % CPU usage by tasks
		fd	 	- % of file descripters used
	ao:
		memoryScanPeriod   - Set memory scan period
		cpuScanPeriod      - Set cpu scan period
		fdScanPeriod       - Set fd scan period
	# sample database using all the different types of statistics
	record(ai,"$(IOC):memory")
		field(DTYP,"VX stats")
		field(SCAN,"I/O Intr")
		field(INP,"@memory")
		field(HOPR,"100.0")
		field(HIHI,"90.0")
		field(HIGH,"60.0")
		field(HHSV, "MAJOR")
		field(HSV, "MINOR")
	record(ai,"$(IOC):cpu")
		field(INP,"@cpu")
		field(HOPR,"100.0")
		field(HIHI,"90.0")
		field(HIGH,"60.0")
		field(HSV, "MINOR")
	record(ai,"$(IOC):fd")
		field(INP,"@fd")
		field(HOPR,"100.0")
		field(HIHI,"90.0")
		field(HIGH,"60.0")
		field(HSV, "MINOR")
	record(ao,"$(IOC):memoryScanPeriod")
		field(OUT,"@memoryScanPeriod")
	record(ao,"$(IOC):fdScanPeriod")
		field(OUT,"@fdScanPeriod")
	record(ao,"$(IOC):cpuScanPeriod")
		field(OUT,"@cpuScanPeriod")
typedef struct aiaodset
	long		number;
	DEVSUPFUN	report;
	DEVSUPFUN	init;
	DEVSUPFUN	init_record;
	DEVSUPFUN	get_ioint_info;
	DEVSUPFUN	read_write;
	DEVSUPFUN	special_linconv;
}aiaodset;
typedef struct devPvt
	int type;
}devPvt;
static long ai_init(int pass);
static long ai_ioint_info(int cmd,aiRecord* pr,IOSCANPVT* iopvt);
static long ai_init_record(aiRecord*);
static long ao_init_record(aoRecord* pr);
static long ai_read(aiRecord*);
static long ao_write(aoRecord*);
aiaodset devAiVXStats={ 6,NULL,ai_init,ai_init_record,ai_ioint_info,ai_read,NULL };
aiaodset devAoVXStats={ 6,NULL,NULL,ao_init_record,NULL,ao_write,NULL };
#define MEMORY_TYPE	0
#define CPU_TYPE	1
#define FD_TYPE		2
#define TOTAL_TYPES	3
/* default rate in seconds (memory,cpu,fd) */
static int default_scan_rate[] = { 10,50,10 };
static char *aiparmValue[TOTAL_TYPES] = {"memory","cpu","fd"};
static char *aoparmValue[TOTAL_TYPES] = {
	"memoryScanPeriod","cpuScanPeriod","fdScanPeriod"};
typedef struct scanInfo
	IOSCANPVT ioscanpvt;
	WDOG_ID wd;
	int 	rate_tick;	/* ticks */
}scanInfo;
static scanInfo scan[TOTAL_TYPES];
static void wdCallback(int type);
static double getMemory(void);
static double getFd(void);
#define SECONDS_TO_STARVATION 60
#define SECONDS_TO_BURN 5
#define SECONDS_TO_WAIT 15
typedef struct cpuUsage {
    SEM_ID        lock;
    unsigned long ticksToDeclareStarvation;
    unsigned long ticksToBurn;
    unsigned long ticksToWait;
    double        nBurnNoContention;
    unsigned long ticksLastUpdate;
    double        usage;
} cpuUsage;
static cpuUsage usage;
static void wdCpu(void);
static double cpuBurn();
static void cpuUsageTask();
static double getCpu(void);
static void cpuUsageInit(void);
    int type;
    if(pass==1) {
        for(type=0;type<TOTAL_TYPES;type++) {
          if(type==CPU_TYPE) {
	      wdStart(scan[type].wd,scan[type].rate_tick,
                  (FUNCPTR)wdCpu,0);
          } else {
                  (FUNCPTR)wdCallback,type);
	return(0);
	scanIoInit(&scan[type].ioscanpvt);
	scan[type].wd=wdCreate();
	scan[type].rate_tick=default_scan_rate[type]*sysClkRateGet();
    cpuUsageInit();
    return 0;
    devPvt* pvt=(devPvt*)pr->dpvt;
    *iopvt=scan[pvt->type].ioscanpvt;
    return 0;
static long ai_init_record(aiRecord* pr)
    int     type;
    devPvt* pvt = NULL;
    char   *parm;
    if(pr->inp.type!=INST_IO) {
	recGblRecordError(S_db_badField,(void*)pr,
		"devAiStats (init_record) Illegal INP field");
	return S_db_badField;
    parm = pr->inp.value.instio.string;
    for(type=0; type < TOTAL_TYPES; type++) {
	if(strcmp(parm,aiparmValue[type])==0) {
		pvt=(devPvt*)malloc(sizeof(devPvt));
		pvt->type=type;
    if(pvt==NULL) {
		"devAiStats (init_record) Illegal INP parm field");
    /* Make sure record processing routine does not perform any conversion*/
    pr->linr=0;
    pr->dpvt=pvt;
    pr->hopr = 100.0;
    pr->lopr = 0.0;
    pr->prec = 2;
    return 0;
    int type;
    devPvt* pvt = NULL;
    char   *parm;
    if(pr->out.type!=INST_IO) {
		"devAoStats (init_record) Illegal OUT field");
    parm = pr->out.value.instio.string;
	if(strcmp(parm,aoparmValue[type])==0) {
		pvt->type=type;
	pr->val = default_scan_rate[type];
    if(pvt==NULL) {
		"devAoStats (init_record) Illegal OUT parm field");
    pr->linr=0;
    pr->dpvt=pvt;
    return 2;
static long ao_write(aoRecord* pr)
    if(!pvt) return(0);
    if(pr->val<=1.0) pr->val=1.0;
    scan[pvt->type].rate_tick = (int)pr->val * sysClkRateGet();
    return 0;
static long ai_read(aiRecord* pr)
    double value = 0.0;
    if(!pvt) return(0);
    switch(pvt->type) {
        case MEMORY_TYPE: value = getMemory(); break;
        case CPU_TYPE: value = getCpu(); break;
        case FD_TYPE: value = getFd(); break;
        default: recGblRecordError(S_db_badField,(void*)pr,"Illegal type");
    pr->val=value;
    pr->udf=0;
    return 2; /* don't convert */
    scanIoRequest(scan[type].ioscanpvt);
    wdStart(scan[type].wd,scan[type].rate_tick, (FUNCPTR)wdCallback,type);
/*Memory statistics*/
#include <memLib.h>
static MEM_PART_STATS meminfo;
    double nfree,nalloc;
    memPartInfoGet(memSysPartId,&(meminfo));
    nfree = meminfo.numBytesFree;
    nalloc = meminfo.numBytesAlloc;
    return(100.0 * nalloc/(nalloc + nfree));
/* fd usage */
#include <private/iosLibP.h>
static double getFd()
    int i,tot;
    for(tot=0,i=0;i<maxFiles;i++)  {
		if(fdTable[i].inuse)
		tot++;
    return(100.0*(double)tot/(double)maxFiles);
    unsigned long ticksLastUpdate = usage.ticksLastUpdate;
    unsigned long ticksNow = tickGet();
    if(ticksNow>=ticksLastUpdate /*ignore tick overflow*/
    && (ticksNow-ticksLastUpdate) >= usage.ticksToDeclareStarvation) {
        usage.usage = 100.0;
        scanIoRequest(scan[CPU_TYPE].ioscanpvt);
    wdStart(scan[CPU_TYPE].wd,scan[CPU_TYPE].rate_tick,(FUNCPTR)wdCpu,0);
    int i;
    double result = 0.0;
    for(i=0;i<5; i++) result += sqrt((double)i);
    return(result);
    while(TRUE) {
	unsigned long tickStart,tickEnd=0;
        int nBurnNow;
        double nBurnNoContention = (double)usage.nBurnNoContention;
	double nBurnContention,newusage;
	nBurnNow=0;
	tickStart = tickGet();
        while(1) {
	    cpuBurn();
	    ++nBurnNow;
            tickEnd = tickGet();
            if(tickEnd<tickStart) break; /*allow for tick overflow*/
            if((tickEnd - tickStart) >= usage.ticksToBurn) break;
        if(tickEnd<tickStart) continue; /*allow for tick overflow*/
        nBurnContention = (double)nBurnNow;
        newusage = 100.0*((nBurnNoContention - nBurnNow)/nBurnNoContention);
        semTake(usage.lock,WAIT_FOREVER);
	usage.usage = newusage;
        semGive(usage.lock);
        taskDelay(usage.ticksToWait);
        usage.ticksLastUpdate = tickEnd;
static double getCpu()
    double value;
    value = usage.usage;
    return(value);
    unsigned long tickStart,tickEnd=0,tickNow;
    int           nBurnNoContention=0;
    usage.lock =
        semMCreate(SEM_DELETE_SAFE|SEM_INVERSION_SAFE|SEM_Q_PRIORITY);
    usage.usage = 0.0;
    usage.ticksToDeclareStarvation = SECONDS_TO_STARVATION * sysClkRateGet();
    usage.ticksToWait = SECONDS_TO_WAIT*sysClkRateGet();
    usage.ticksToBurn = SECONDS_TO_BURN*sysClkRateGet();
    /*wait for a tick*/
    while(tickStart==(tickNow = tickGet())) {;}
    tickStart = tickNow;
    while(TRUE) {
	cpuBurn();
	nBurnNoContention++;
        if(tickEnd<tickStart) break; /*same test as cpuUsageTask*/
    if(tickEnd<tickStart) printf("cpuUsageInit logic error\n");
    usage.nBurnNoContention = (double)nBurnNoContention;
    usage.ticksLastUpdate = tickGet();
    taskSpawn("cpuUsageTask",255,VX_FP_TASK,3000,(FUNCPTR)cpuUsageTask,
	0, 0, 0, 0, 0, 0, 0, 0, 0, 0);
devVXStats and task crash Andy Foster
Re: devVXStats and task crash Marty Kraimer
Prev: Re: dbCaLink and broadcast messages Kevin Tsubota
Next: RE: dbCaLink and broadcast messages Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: devVXStats and task crash Marty Kraimer
Next: New MCP750s That Don't Run VxWorks Boot Code Susanna Jacobson
