1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problems with GSOctalRS232
Cc: "'Leng Yongbin '" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Wed, 25 Apr 2001 09:32:17 -0500
Mark Rivers wrote:
> Here is an example from my st.cmd which works fine.  Note that I don't call
> tyGSoctalModuleInit("GSIP_OCTAL232",0x80,0,0) at all.  I guess initOctalUART
> does this?  We are using MPF in our application.
Mark is using MPF, which has a different driver to the tyGSOctal one,
hence the different initialization.  The tyGSOctal driver provides a true
vxWorks serial port which is accessed in the Unix manner by opening a file
descriptor, whereas MPF uses its own interface which was designed for
EPICS.  "ipacAddCarrier" is the only initialization command that will be
common to both drivers.
- Andrew
Every great idea appears crazy to start with.
RE: Problems with GSOctalRS232 Mark Rivers
Prev: RE: Problems with GSOctalRS232 Mark Rivers
Next: gdct built with ivtools Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
