1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CAN questions
To: tech-talk <[email protected]>
Date: Tue, 17 Apr 2001 20:36:38 +0200
John Maclean wrote:
> At the APS we are considering adopting CAN for one of our applications
> requiring some remote I/O.
> This particular project needs ~32 binary I/O channels and ~6 low res. (8
> to 12 bit) analog inputs per node.
> Is any one already using a similar off-the-shelf solution, or do people
> generally build their own custom CAN board? Is anyone interfacing
> CANopen or DEVICEnet products to EPICS?
> Someone, (management), also asked me if I knew of anyone who's had a bad
> experience with CAN. I didn't, but as a matter of interest I'd be
> interested to hear of any experiences with CAN, either bad or good.
At BESSY we use CAN for most of the standard I/O, especially all the
Power Supplies.
We developed CAN bus support for EPICS quite a while ago. It implements
a subset of CAL (CAN Application Layer) which I believe is the same as
CANopen. CAL/CANopen includes a connection based protocol with
acknowledged data transfer (but also unacknowledged broadcasts). The
software was designed so that other protocols can be added easily and
multiple protocols can be used at the same time (therefore named it
MultiCAN).
We use VME cards made by esd (VME-CAN2 and VME-CAN4, having 2 and 4
ports resp.) to interface to the CAN bus. On the other side of the cable
there are two kinds of hardware: a general purpose temperature
measurement module (Selectron), and 'self-made' embedded controllers
that connect to the analog and digital (and mixed) I/O cards.
Experiences: Very reliable. You can plug nodes off and on at runtime
without anything getting wobbly. Fast if segment not too long. Warm
reboot supported.
Ben
CAN questions John Maclean
Prev: Re: [Fwd: Interrupt Epics Driver] Benjamin Franksen
Next: EPICS training materials Nick Rees
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CAN questions Bernd Schoeneburg
Next: Interrupt on MV2302 Weixing Cheng
