1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CAN questions
To: John Maclean <[email protected]>, tech-talk <[email protected]>
Date: Thu, 12 Apr 2001 13:12:02 -0800
At 02:22 PM 4/12/01 -0500, John Maclean wrote:
>At the APS we are considering adopting CAN for one of our applications
>requiring some remote I/O.
>This particular project needs ~32 binary I/O channels and ~6 low res. (8
>to 12 bit) analog inputs per node.
>Is any one already using a similar off-the-shelf solution, or do people
>generally build their own custom CAN board? Is anyone interfacing
>CANopen or DEVICEnet products to EPICS?
>Someone, (management), also asked me if I knew of anyone who's had a bad
>experience with CAN. I didn't, but as a matter of interest I'd be
>interested to hear of any experiences with CAN, either bad or good.
>Thanks,
>John.
At present we're trying to get DeviceNet going with EPICS, starting with
some code from "Leng Yongbin" <[email protected]> for the SST 5136-DN-VME
board.
Originally we started out with the IP-DeviceNet from SBS.  It turns out
that the firmware they supply with the card (it has an on-board cpu)
is seriously broken, and support for the device is non-existent.  I
can't recommend that particular approach.
Both of the aboved mentioned outfits also supply firmware for CAN (it
doesn't have the DeviceNet layer on top).
Hope this helps.
-bill
CAN questions John Maclean
Prev: CAN questions John Maclean
Next: Re: CAN questions Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
