1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Interrupt Epics Driver
To: [email protected], [email protected]
Date: Wed, 11 Apr 2001 07:55:41 -1000 (HST)
At Keck we have a driver for the XYCOM XVME 540 12 bit analog I/O board,
which uses interrupts. I can provide that as an example if you want.
	ftp ftp.keck.hawaii.edu
	login as anonymous
	cd outgoing
	cd epics
	cd drivers
	cd xy540    (you need to use 'ls' and not 'dir')
cheers,
	Allan
> From [email protected] Tue Apr 10 22:08:04 2001
> From: "Weixing Cheng" <[email protected]>
> To: <[email protected]>
> Subject: Interrupt Epics Driver
> Date: Wed, 11 Apr 2001 16:07:42 +0800
> MIME-Version: 1.0
> X-Priority: 3
> X-MSMail-Priority: Normal
> X-Mailer: Microsoft Outlook Express 5.00.2615.200
> X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2615.200
> Content-Transfer-Encoding: 8bit
> X-MIME-Autoconverted: from base64 to 8bit by keck.hawaii.edu id WAA08676
> Hello, everyone:
>     I have developed the epics driver for AcromagAVME9321, which is a 12 bit AD card.it was working under the continuous mode. Now I want to use the interrupt mode, what should I deal with the driver code and .db file ? Thank you for your suggestion.
> Cheng Weixing
Prev: Interrupt Epics Driver Weixing Cheng
Next: Re: CA clients on vxWorks Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: CA on MacOS X Noboru Yamamoto
