Attached is the script we use at Jefferson Lab for this purpose. Feed it
the name of a top level schematic and it creates a list of dependencies
for inclusion in Makefiles.
--Brian Bevins
Accelerator Controls Group
Jefferson Lab
Ralph Lange wrote:
> Andy,
> I just checked the CVS: the change you are referring to was introduced
> to RULES.Host in September 1997, between 3.13.0.beta11 and beta12, so
> please excuse us if we don't instantly remember all the details...
> Rozelle is right: at that time all the database generation rules were
> shifted into a local $TOP/config/RULES.Db file that had additional
> features over the "standard" rules in base. The document that Rozelle
> pointed you to describes the details. Any newly generated application
> would of course contain these rules.
> At that point the "standard" rules in base were cleaned up, which led to
> the $(DEPSCHS) dependency being thrown out of RULES.Host - a change that
> probably only shows up when converting old applications without creating
> a new $TOP with the new rules.
> Please note also that at the APS, where the Makefile system development
> is done, CapFast is not used. At BESSY, where the DB rules originate
> from, CapFast is used, but without hierarchical structures. At LANL
> hierarchical CapFast schematics are used, but not with $(DEPSCHS).
> IMHO the best way to handle the hierarchical CapFast drawings would be
> writing a perl script that analyzes the schematics files and extracts
> the dependencies into a file that can be included by the Makefile ...
> whoever speaks the .sch language well enough may volunteer for that.
> Until then, use a local RULES.Db that still has the $(DEPSCHS).
> Hope this helps,
> Ralph #! /bin/csh -f
# MAKE CAPFAST SCHEMATIC DEPENDENCIES:
# CAPFAST USER SYMBOL HIERARCHY VIEWER & SYMBOLIC LINK MAKER
# File: mkDepends
# Author: George Lahti
# Date: 30 March 1995
# This sch shell script starts with a root CAPFAST schematic (.sch file) and
# determines all symbols and related schematics in the symbol hierarchy. To
# get these symbols, it can search user defined directories to find the .sym
# and .sch files. If these files are found in other directories, then a
# symbolic link will be made to them. This script also creates a schematic
# depedency file (.depends file) to be used by the makefile. Standard out
# shows the symbol hierarchy, using various indents for each level.
# Summary of actions:
# 1. Symbol hierarchy to standard-out.
# 2. Creates a hierarchical .sym/.csh dependency file (.depends).
# 3. Creates symbolic links for .sym/.sch files not in this directory.
# 4. Creates a .noSym log file for unfound symbols and failed links.
# Usage: mkDepends ROOT_SCHEMATIC [SEARCH_PATH_FILE]
# where ROOT_SCEMATIC is the root (base) .sch file name (with or
# without the .sch file suffix), and SEARCH_PATH_FILE is the name
# of the file that lists the firectory paths to search if the
# .sym and .sch files are not found in the present directory.
# SEARCH_PATH_FILE Format: This is an ascii file, with one directory
# path per line. This file can be empty. But usually the file
# name is not even given to the command if there are no search paths.
# It is usually best to give relative paths, since the whole
# directory tree could be place anywhere. Caution, do not use
# "nO_sEaRcH" as the name of the file; it is for internal use only.
# Example: ..
# ../templates
# ../other
# Search order:
# 1. Present directory.
# 2. User supplied search path file (the same order as in the file).
# 3. System directory.
# CAUTION: This is a recursive shell script file. The third and
# fourth arguments are used only for the recursion calls. The
# user should not enter more than 2 arguments.
# Help and error message.
if ($1 == "") then
echo "CAPFAST USER SYMBOL HIERARCHY VIEWER & SYMBOLIC LINK MAKER"
echo "Error: Missing some arguments."
echo "Usage: mkDepends SCH_FILE SEARCH_PATHS_FILE"
echo "Example: mkDepends rfn02 schPaths"
echo "Caution: do NOT enter more than 2 arguments."
exit 0
endif
# Present command name with path.
set thisCmd = $0
# User command inputs.
set fileBase = $1:r
if ($2 == "") then
set searchFile = "nO_sEaRcH"
else
set searchFile = $2
endif
set symFile = $fileBase.sym
set schFile = $fileBase.sch
# Path to the Epics system symbols.
set sysPath = $P3/library/epics
# Determine the search path.
if ($searchFile == "nO_sEaRcH") then
set searchPath = ""
else
if (-r $searchFile) then
set searchPath = `cat -v $searchFile`
else
echo "mkDepends: ERROR cannot open search file ($searchFile)"
exit 1
endif
endif
# Dependency output file (argument #3 of the recursive call).
if ($3 == "") then
# First time through, create a new dependency file with header text.
set dependsFile = $fileBase.depends
rm -f $dependsFile
echo "# CAPFAST Schematic User Symbol Hierarchy." > $dependsFile
echo "# The base schematic is: $schFile" >> $dependsFile
echo -n "SCH_OBJS = " >> $dependsFile
# First time through, remove the .noSym file.
set noSymLogFile = $dependsFile:r.noSym
rm -f $noSymLogFile
else
set dependsFile = $3
endif
# Hierarchy level (argument #4 of the recursive call)
if ($4 == "") then
# First time through, set the hierarchy level to 1.
set recursionLevel = 1
echo "CAPFAST USER SYMBOL HIERARCHY FOR $schFile.sch"
echo "DEPENDENCY FILE IS $dependsFile"
else
@ recursionLevel = $4 + 1
endif
# Search for the .sch file.
set schFound = 0
if (-r ./$schFile) then
set schFound = 1
else
foreach onePath ($searchPath)
if (-r $onePath/$schFile) then
echo "ln -s $onePath/$schFile $schFile"
if (-r $schFile) then
set schFound = 1
else
echo "mkDepends: ERROR link failed ($schFile)"
echo "$schFile --- link failed" >> $noSymLogFile
endif
break
endif
end
endif
# Send symbol name information to standard out and the .depends file.
if ($recursionLevel != 1) then
@ lev = $recursionLevel
@ lev--
while ($lev)
echo -n " "
echo -n " " >> $dependsFile
@ lev--
end
if ($schFound == 1) then
echo "$fileBase"
echo "$symFile $schFile \" >> $dependsFile
else
echo "$fileBase (no .sch file)"
echo "$symFile \" >> $dependsFile
endif
else
echo "$fileBase"
echo "$schFile \" >> $dependsFile
endif
endif
# Process all symbols in this .sch file.
# Make list of all symbol references in this .sch file.
set symbolList = `awk '/^use/ { if ($7 != "frame") print $2 }' \
$schFile | sort -u`
# For each symbol reference, check if the symbol file (.sym) exists.
# If it doesn't exist, then append this symbol name to the symbol-
# not-found log file. If the symbol exists and it is a user symbol,
# then execute a recursive call of this script file to read the
# associated .sch file.
foreach symbol ($symbolList)
if ($symbol == "inhier" || $symbol == "outhier") then
continue
endif
set symFile = $symbol.sym
if (-r ./$symFile) then
$thisCmd $symbol.sch $searchFile $dependsFile $recursionLevel
continue
endif
if (-r $onePath/$symFile) then
echo "ln -s $onePath/$symFile $symFile"
if (-r $symFile) then
else
echo "mkDepends: ERROR link failed ($symFile)"
echo "$symFile --- link failed" >> $noSymLogFile
endif
# Break out of this foreach, but continue with the outer foreach.
break; continue
endif
end
if (-r $sysPath/$symFile) then
continue
endif
echo $symbol >> $noSymLogFile
end
endif
# Top level completion actions.
if ($recursionLevel == 1) then
if ($schFound == 0) then
echo "ERROR root .sch file does not exist ($schFile)"
endif
# Append a blank line to the end of the .depends file, so that
# the trailing \ character does not cause any problems.
echo "\n" >> $dependsFile
# Clean up the .noSym file.
if (-r $noSymLogFile) then
sort -u $noSymLogFile > mkDepends.tmp
mv mkDepends.tmp $noSymLogFile
endif
endif
- Re: Capfast Rules in 3.13.4 RULES.Host Rozelle Wright
- Re: Capfast Rules in 3.13.4 RULES.Host Ralph Lange
[no subject] Mohan Ramanathan
Sequencer 2.0.0 Mythili Srinivasan
<2001>
Re: Capfast Rules in 3.13.4 RULES.Host Nick Rees
<2001>
