1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: ca client connection pattern
To: "Geoff Savage" <[email protected]>
Cc: <[email protected]>
Date: Thu, 29 Mar 2001 12:16:24 -0700
> Our network masks are now set at FFFFFF00.  We spent a day last week
> upgrading to this more restrictive mask on all our iocs when our hosts
> changed to the same mask for security reasons.
I'm am guessing that your problem is that there are large numbers of
machines on your network that have not yet configured to the new netmask.
They are all replying to every CA broadcast with "ICMP destination unreachable"
and this is swamping the client's UDP input queue. This can result in very
unreliable behavior that strongly depends on network topology (the responses
that arrive first get through and all others are discarded). As I mentioned,
you can use snoop (or some other sniffer) to obtain a list of hosts that must
be fixed. You may also decide to place your control system behind a firewall.
Jeff
CA clients on vxWorks Matthieu Bec
Re: ca client connection pattern Geoff Savage
Prev: Re: ca client connection pattern Geoff Savage
Next: CA clients on vxWorks Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
