I must be the only person that does this but....
When building EPICS I keep the installation tree and the source code tree
separate. For R3.13.4 I did this by redefining INSTALL_LOCATION_BASE in
CONFIG_SITE to be the install location I wanted.
The problem was that there is a bug when installing the configuration
files because of all the .PHONY definitions in CONFIG_BASE. I believe
these are there to speed up the build, but they also mean that a number of
the configuration files do not get installed.
I suggest either:
1. Removing the .PHONY declarations or
2. putting them in an ifndef MAKE_CONFIG_DIR block, and only defining
MAKE_CONFIG_DIR in the Makefile.Host in the config directory.
I did the latter.
Nick Rees
Joint Astronomy Centre Ph: +1 (808) 961-3756
660 N. Aohoku Place Fax: +1 (808) 961-6516
Hilo, HI. 96720 Internet: [email protected]
Re: Fortran CA Client Interface Andrew Johnson
RE: R3.13.4 Build Redman, Russell O.
<2001>
EPICS meeting at PSI - agenda development Bob Dalesio
<2001>
