1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem when compiling cross compiler for PowerPC
To: shen guobao <[email protected]>
Cc: [email protected]
Date: Mon, 05 Mar 2001 15:45:24 +0100
  There is an error in the configuration files for the PowerPC. I never
really investigated this, but could build the cross compiler with the
following recipe:
1. The build process stops during libiberty. But during the
binutils-build a functioning libiberty was already built. So copy the
the libiberty directory from binutils to the gcc directory. But keep the
files choose-temp.c and mkstemps.c and rebuild libiberty.a from hand (ar
rc libiberty.a argv.o ...)
2. again make cross
3. make will configure newly the directory powerpc-wrs-vxworks and tries
to build target specific tool which are not needed. While make is again
configuring delete the directory powerpc-wrs-vxworks and make should
finish building gcc.
4. make install
 This looks awkward but it worked for me. I never found the time to find
a fix for the configuration. Maybe s.o. else?
 Btw. I can provide an RPM for RH 6.2 (7.) systems based on gcc 2.8.1
and binutils 2.9.1 for PowerPC and the 68k architectures.
  Cheers, Markus
shen guobao wrote:
> Hello, every one,
> Now I want to build the cross compiler for powerpc in RedHat6.2,
> I can succeed in building binutils.But when I compile the gcc
> like the following steps:
>    $ ../gcc-2.95.2/configure --target=powerpc-wrs-vxworks \
>     --prefix=/home/me/cross/ppc -v \
>     --with-headers=/usr/local/cross/ppc/target/h \
>     --with-newlib
>     $ make all install LANGUAGES="c c++"
> Gives me an error:
> ../../../gcc-2.95.2/libiberty/choose-temp.c:38:67: sys/file.h no such file
> or directory
> make: *** [all-target-libiberty] Error 2
> But I do that for i386 or m68k as that, it is ok.
> And I find that there are i386 and m68k directory in gcc-2.95.2/gcc/config,
> but I cant find powerpc .
> Can anyone give me some advice?
> Thanks,
> guobao shen
> SSRF, Shanghai
> 2001-03-05
Problem when compiling cross compiler for PowerPC shen guobao
Prev: Problem when compiling cross compiler for PowerPC shen guobao
Next: Fortran CA Client Interface Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
