1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How can I build my cross compiler in RedHat6.2 for i386 target?
To: "Kay-Uwe Kasemir" <[email protected]>
Cc: <[email protected]>, <[email protected]>
Date: Fri, 2 Mar 2001 14:46:09 +0800
Thank you.
I have succeeded in that.
I just take a new binutils package, binutils-2.9.1.tar.gz.
----- Original Message -----
To: "shen guobao" <[email protected]>; <[email protected]>
Sent: Friday, March 02, 2001 12:20 AM
| Hello Shen:
| Maybe this is the not problem, but are you sure that you have
| the correct version of the sources?
| The "real" cross compiler from WRS reports:
| ./c++68k --version
| cygnus-2.7.2-960126 egcs-971225 tornado 2.0
| ./c++386 --version
| ./c++ppc --version
| -> For Tornado2, the WRS compiler was based on gcc/g++
| "cygnus-2.7.2-960126 egcs-971225" for the 68k, 386 and ppc target.
| Since this is GNU code, WRS has to merge everything they did back into
| the GNU sources
| -> If you get that version of the GNU sources, you should be able to build
| your own cross compiler.
| But: If you just get any version of the GNU sources, maybe more recent ones,
| then those might not build as a GNU cross compiler.
| I believe that Markus Janousch at PSI was succesful in building
| a Linux->ppc cross compiler which seems to work OK, it reports:
| ./g++ppc --version
| 2.8.1
| -> The GNU 2.8.1 sources allow to build a cross compiler for the PPC target,
| but I'm not sure if this would work for other targets.
| Ernest, I copied you because I remember you were succesful with one target.
| Which one was it and what version of the GNU sources did you use?
| Thanks,
| -Kay
Prev: RE: problem with EPICS pid record Mark Rivers
Next: PMAC Support:Where? Janousch Markus
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
