1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: where to load vxWorks.sym
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 20 Feb 2001 10:20:06 -0600 (CST)
  >> Is it now S.O.P. to boot operational IOC's from the vxWorks files that are
  >> in the  ~vw/tornado101  subdirectory,  and not those under <top> ?  Did we
  >> forget a 'switch' in the build?
  > It is T.R.O.P (The Recommended Operating Practice), although you have to
  > manually ensure that the IOC is booting from the same version of Tornado
  > (1.0.1, 2.0 etc.) that the software was built for (usually not a problem).
As some sites even have their operational kernels on a (or multiple)
different server(s) on a different network in a different place and boot
in a different way (e.g. using bootp / tftp), the S.O.P. is actually
B.Y.O.K. (Boot Your Own Kernel).
Ralph
where to load vxWorks.sym Paul Sichta
Re: where to load vxWorks.sym Andrew Johnson
Prev: Re: where to load vxWorks.sym Andrew Johnson
Next: EPICS Collaboration Meeting @ PSI Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
