1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Callbacks and the PCAS question.
Date: Tue, 20 Feb 2001 09:10:37 -0600
Mark,
Of course you can do it this way.  You can also use the client wait feature of
the scan record directly.
The problems I have with this are: 1)  It implies the server tool is deficient
since not all server functionality is supported properly. This is a general
problem for us since the server tool is currently a generic tool integrated
into several acquisition systems and at least one motion control system.  2)
It also means you have to have a VME crate in the loop to support the Busy
record.
I've known ways around the problem for quite a while, but since the interface
I've built around the PCAS is in general use now, I think I really need to
solve the problem rather than work around it.
Brian
Mark Rivers wrote:
> Brian,
> The way we do this is to make the data acquisition program be a channel
> access client, rather than a channel access server.  The scan software
> writes a 1 to a local "Busy" record, which is just like a binary output
> record except it does not do the forward link until its value goes back to
> zero.
> The acquisition program monitors that Busy record. When it goes to 1 it
> starts collecting data.  When the data acquisition is done it sets the Busy
> record back to zero, which lets the scan continue.  This method does not
> have a problem with a 30 second limit.
> Mark
RE: Callbacks and the PCAS question. Mark Rivers
Prev: where to load vxWorks.sym Paul Sichta
Next: Re: where to load vxWorks.sym Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Callbacks and the PCAS question. Mark Rivers
Next: MATLAB and EPICS Channel Access Ernest L. Williams Jr.
