1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Delays in seq records
To: Tim Graber <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 16 Feb 2001 12:50:15 -0600 (CST)
  > If a user makes a mistake and wants to restart the process, the time he/she
  > needs to wait for the record to finish processing can be too long. My
  > question is, once the record is executed is there a way to stop the record
  > from processing or reset it.
Tim,
the record sets up watchdog timers to do the delayed processing. There
is currently no easy way to cancel the operation of a seq record once
you pushed the button.
(You could of course look at the seq record code and write a function to
be used within a subroutine record that cancels the timer and resets the
seq record to a usable state. That would not be a good design neither
easy to do, though.)
(Or you could add this functionality to the seq record. I'm sure there
are other people who would appreciate this.)
I would switch to using the sequencer with a state machine that looks
for a "cancel" bo record. When the sequences are rather long or
complicated and don't need many instances, the sequencer is the better
tool.
Good luck!
Ralph
[no subject] Tim Graber
Prev: [no subject] Tim Graber
Next: Re: Your Message Sent on Fri, 16 Feb 2001 12:16:07 -0600 Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
