1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: dm won't load gif
To: [email protected]
Date: Tue, 13 Feb 2001 14:36:10 -0800 (PST)
Deb Kerstiens wrote:
> Hi Ian,
> First a disclaimer:  though I'm the original author of dm, I haven't
officially
> supported it for quite some time :-)
> John Faucett just reported the same problem.  I haven't actually used the gif
> feature for quite awhile.  I think Andrew is likely right about the format
> issue.  The gif code was initially "borrowed" from medm and modified for use
> with dm. I'm guessing the newer version of gif support could be "borrowed"
from
> medm and used to upgrade the code.  I can't promise to get to it any time soon
> unfortunately, but will let you know if I do.
>Ian Smith wrote:
> > I can't get dm to load a gif image.  I get the error message: loadGIF: not
> > a GIF file.  I've tried it with monochrome and 256 colour versions and
> > passed it through xv to no avail.  The image is attached.
I would appreciate hearing of any success in loading gif's in dm.
I am currently using dm in R3.13.1 release and I couldn't get it to
load either a gif89a or a gif87a image when I was developing some pages
last year.
	regards,
	Noel Giffin
	TRIUMF Safety Group
Re: dm won't load gif Ian Smith
Prev: Wavetek Model 39 device support ? Brian McAllister
Next: RE: dm won't load gif Kenneth Evans, Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: dm won't load gif Chestnut, Ronald P.
Next: Re: dm won't load gif Ian Smith
