1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: dm won't load gif
To: [email protected], [email protected]
Date: Tue, 13 Feb 2001 13:41:39 -0700
Hi Ian,
First a disclaimer:  though I'm the original author of dm, I haven't officially
supported it for quite some time :-)
John Faucett just reported the same problem.  I haven't actually used the gif
feature for quite awhile.  I think Andrew is likely right about the format
issue.  The gif code was initially "borrowed" from medm and modified for use
with dm. I'm guessing the newer version of gif support could be "borrowed" from
medm and used to upgrade the code.  I can't promise to get to it any time soon
unfortunately, but will let you know if I do.
Sorry :-(
deb
> I can't get dm to load a gif image.  I get the error message: loadGIF: not
> a GIF file.  I've tried it with monochrome and 256 colour versions and
> passed it through xv to no avail.  The image is attached.
> Help!
> TIA
> Ian A Smith					Telephone: (808) 961 3756
> Joint Astronomy Centre				Fax:       (808) 961 6516
> 660 N. A'ohoku Place					   (808) 969 6591
> University Park					Web: http://www.jach.hawaii.edu
> Hilo
> Hawaii
> 96720
Prev: Re: dm won't load gif Andrew Johnson
Next: RE: dm won't load gif Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
