1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS runtime problems on Motorola mv162-P242E CPUs
To: Dave Barker <[email protected]>
Date: Thu, 8 Feb 2001 07:44:08 +0100
>>>>> "Dave" == Dave Barker <[email protected]> writes:
  > Hi,
  > We are having run time problems running EPICS on the new Motorola MV162
  > P242E cards. I am running VxWorks 5.2, and have tried EPICS R3.12.2 and
  > R3.13.3. In all cases the CPU freezes or locks up, usually within 24
  > hours. We think it crashes more quickly if sequencers are running.
  > Has anyone else had problems running EPICS on these cards?
  > I'm in the process of seeing if we require a BSP upgrade from Wind River
  > (we may have to upgrade to tornado in order to get the latest BSPs)
  > many thanks,
  > Dave Barker.
  > Dave Barker                | Tel    Office: 509 372 8103 (msg service)
  > LIGO Hanford Observatory   |        Lab 0:  509 372 8156
  > P.O. Box 1970; MS S9-02    |        Lab 1:
  > Richland                   | Fax    509 372 8137
  > WA 99352                   | e-mail [email protected]
  > United States of America   | S/W Engineer, UNIX Sys Admin.
Dave,
we've tested the MVME162-P344E (wich should replace the old MVME162-532a)
together with EPICS.
The good news is that the board was compatible to the old one regarding the
BSP.
The bad news is that we encountered interrupt problems which caused a
reboot of the IOC after some ours.
I talked with my distributor and he told me that the first series of the
Petra ASCISs has definitively BUGs regarding interrupts. Therefore Motorola
has replaced the Petra ASIC with a new one. As far as I know the boards
with the new ASIC habe the letter 'A' after the 'P' . The new MVME162-P344E
is now called MVME162-PA344E.
Regards
Joachim
 BESSY mbH  | Albert-Einstein-Strasse 15  | Phone : (+49) 30 / 6392 - 4864
            | D - 12489 Berlin, Germany   | Fax   :                 - 4859
            | http://www.bessy.de/        | mailto:[email protected]
EPICS runtime problems on Motorola mv162-P242E CPUs Dave Barker
Prev: Re: EPICS runtime problems on Motorola mv162-P242E CPUs Maren Purves
Next: RE: EPICS runtime problems on Motorola mv162-P242E CPUs Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
