1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to configure the Capfast?
To: shen guobao <[email protected]>
Cc: [email protected]
Date: Thu, 21 Dec 2000 11:07:57 -0500
One thing you should do is to make sure that ~p3/library/epics appears
in the symbol search path. To do this:
Start Capfast.
>From the menubar, select Options->Search Path->Show Search Path.
The search path will be displayed at the bottom of the window. If
~p3/library/epics does not appear in the search path, you can add it
with Options->Search Path->Add Directory to Beginning.
I hope that helps.
--Brian Bevins
  Accelerator Controls Group
  Jefferson Lab
shen guobao wrote:
> Hello,
> Recently we have purchased the Capfast3.10.2 from Phase 3.
> After I finished install, I cant find the "epics" directrory in the
> ~p3/library
> and some relative mnu file in ~p3/wcs/lib/menus/new. As the
> "cf-epics-configure.txt"
> file,I should get the library and menus from other EPICS members.
> But I have downloaded the "epicsRecSym.tar.gz" and "menus.EPICS.tar.gz"
> from Phase3
> ftp server. In  I made the "epics" directory, and decompress the
> "epicsRecSym.tar.gz" file in "epics" the "menus.EPICS.tar.gz" in
> ~p3/wcs/lib/menus.new.
> After that, I type "xschedit&" in my sh(Bourne Shell), all things seem
> ok.
> But when I select Part->EPICS Library(small)->analog in, it gives the
> following error:
>     searching for file...done
>     Can't read file 'eais': No such file or directrry
> But in ~p3/library/epics, "eais.sym" is there.
> How can I do? Any answer is welcome and appreciated.
> Thanks.
> shen guobao
> Shanghai Synchrotron Radiation Center
> 2000/12/21
Re: How to configure the Capfast? shen guobao
Prev: How to configure the Capfast? shen guobao
Next: PMC and PC-MIP configuration for PowerPC Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: How to configure the Capfast? shen guobao
