g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: dbNameToAddr...
To: tech-talk@aps.anl.gov
Date: Tue, 14 Dec 1999 18:45:37 -0500 (GMT)
Hi all!
  I'm running EPICS on target shell.Whenever I try commands involving the
routine, "dbNameToAddr" they get failed.Like,dba,dbpr etc.,.In short I'm
not able to access any fields of the record.
-> dba("aiExample1.VAL")
Record Address: 0x2 Field Address: 0x2 Field Description: 0x3b4c178
   No Elements: 62427488
   Record Type:
data access
Exception current instruction address: 0x001347dc
Machine Status Register: 0x0000b030
Data Access Register: 0xbf3efbe7
Condition Register: 0x48400042
Data storage interrupt Register: 0x40000000
1b34ec vxTaskEntry    +60 : shell ()
1a4e68 shell          +18c: 1a4e94 ()
1a50b8 shell          +3dc: execute ()
1a523c execute        +d8 : yyparse ()
1d90c8 yyparse        +7a8: 1d7010 ()
1d7188 yystart        +8f8: dba ()
filename="../dbTest.c" line number=792
Record Not Found dbNameToAddr error
3a1b7fc dba            +38 : 3a1de98 ()
3a1df6c dbhcr          +270: 1a0930 ()
1a0930 fioFormatV     +784: strlen ()
shell restarted.
->dbPvdDump(pdbbase,1)
Process Variable Directory
dbPvdHashTableSize 512 dbPvdHashTableShift 1
025=001  tornado:calcExample
047=001  tornado:aiExample3
093=001  tornado:aiExample
223=001  tornado:aiExample2
303=001  tornado:calcExample1
311=001  tornado:xxxExample
315=001  tornado:calcExample3
319=001  tornado:aiExample1
353=001  tornado:calcExample2
End of Process Variable Directory
value = 35 = 0x23 = '#'
dbDumpPath gives a message that path was not found.Is that any problemm
with dbentry or pdbbase?
dbnr,scanppl,dbDumpFldDes,dbDumpRecord etc., are working fine.
All suggestions are invited.Thanks in advance.
Mythili.S.
p.s: One more thing,Whenever I tried to create an 'example' application
using templates,I've to make the files under each subdirectory
individually,as the 'Makefile' which is supposed to get created in
<apptop> is not getting created.This is the content of <apptop>
app1app  bin  config db dbd include iosBoot javalib
Prev: stripTool Rolf Keitel
Next: Delay of Maximize Severity in OUT Links Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
