1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: reading arrays with dbr_ctrl_xxx from CA-Server
To: [email protected]
Date: Wed, 13 Dec 2000 19:03:36 +0100
Dear all,
I am using the CA-Server (EPICS R3.13.3) on Linux and Windows and
encountered the following problem.
Reading an array with caget works fine, but trying to read the same
array via a CDEV/CA-client results in an internal error on the server
(you can easily verify this with the simple server in the
src/cas/example/simple-directory).
As far as I understand, the CDEV/CA-client always uses the DBR_CTRL_XXX
type to request data. The CA-Server checks the application-type and uses
the corresponding prototype gdd-object (gddcontainer for dbr_ctrl_xxx),
which is defined in gddAppsDef.cc. But the value-gdd in the gddcontainer
is defined as of type gddScalar. The CA-Server can't modify the bounds
and type of the value-gdd, because it is managed and flattened ==>
internal error.
Maybe a solution could be to differentiate between array and scalar
dbr_ctrl-prototypes, when registering them in the
gddApplicationTypeTable?
My first approach was, to unmark the Managed/Flat-flags of the
gddContainer, to be able to change bounds and type of the value-gdd. It
works, but it is a performance impact and I am not really happy with it.
Has anyone else encountered the same problem, or any suggestions?
Jens
Jens Eden; PTB
Re: reading arrays with dbr_ctrl_xxx from CA-Server Benjamin Franksen
Prev: help decipher inet path Allan Honey
Next: Re: Proposals for the Next Generation CA Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: reading arrays with dbr_ctrl_xxx from CA-Server Benjamin Franksen
