1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Access security by IP number?
To: "'[email protected]'" <[email protected]>, Mark Rivers <[email protected]>, EPICS Tech-Talk <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Sun, 12 Nov 2000 10:42:21 -0600
> When a CA client opens a connection to an IOC, it transmits its host
> and user name. It's these strings that the access security information
> is checked against.
> What makes you want to use IP numbers instead?
Here are 2 reasons this might be desireable:
1) IP numbers are more difficult to spoof if they are coming from another
subnet.  On Unix systems one can change the "hostname" which CA security
sees without even rebooting.  I realize that CA security is not intended to
stop determined hackers, but even an impatient operator can bypass security
trivially with hostname (I know, I've seen it done!)
2) IP numbers are more "stable" than hostnames.  We have had many problems
where the hostname presented by our CA clients (typically NT machines) has
changed from a fully qualified domain name (e.g. ford.cars.aps.anl.gov) to a
simple name (e.g. ford).  We don't know what caused these changes (NT
service packs?) but it is a pain, since the CA security database has to be
frequently modified.  IP numbers would not have changed in this
circumstance.
Mark Rivers
Prev: EPICS VME ControlNet interface support Tang, Johnny Y
Next: Re: GPIB Problems Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Access security by IP number? Ralph . Lange
Next: EPICS VME ControlNet interface support Tang, Johnny Y
