1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Download vxWorks to IOC
To: chengwx <[email protected]>
Cc: [email protected]
Date: Fri, 27 Oct 2000 10:04:11 -0500
chengwx wrote:
> Attaching network interface ei0... done.
> Attaching network interface lo0... done.
> Loading... 413736 + 43300 + 35280                 /* the ioc stopped
> here, no moving  at all*/
>  What does that mean? ( when ftp from another PC with the user "cheng",
> I can see
> all these files in directory "/usr/local/project/....")
The bootrom successfully loaded the vxWorks image you asked it to (the
presence of the three numbers tell you that), but on running it the CPU
crashed completely.  There's something wrong with that vxWorks boot file,
but we can't tell you any more than that.  If you can, try changing the
file name you boot to
	<path to tornado>/target/config/<your target type>/vxWorks
to see whether that boots properly.  If you copied the vxWorks file to
that system using ftp, make sure that you selected binary mode to do the
copy.
- Andrew
Every great idea appears crazy to start with.
Download vxWorks to IOC chengwx
Prev: Re: Download vxWorks to IOC Burkhard W. Kolb
Next: Collaboration Meeting 1:00 pm November 13th through 1:00 pm November 16th Leo Dalesio
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Download vxWorks to IOC Kay Kasemir
