1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Debian Gnu g++ problem
To: "Burkhard W. Kolb" <[email protected]>
Cc: [email protected]
Date: Wed, 25 Oct 2000 07:11:17 +0200 (CEST)
On Tue, 24 Oct 2000, Burkhard W. Kolb wrote:
> Hi,
> we recently upgraded our Linux cluster to Debian 2. I tried to make
> a freshly downloaded R3.13.3 base.
> The compiler has the version:
> g++ -v
> Reading specs from /usr/lib/gcc-lib/i386-linux/2.95.2/specs
> gcc version 2.95.2 20000220 (Debian GNU/Linux)
> I get the following very bad error message:
> g++  -Wtraditional    -O  -Wall -Wmissing-prototypes
> -Woverloaded-virtual -Wwric
> In file included from ../aitConvert.cc:141:
> aitConvertGenerated.cc: In function `int
> aitConvertFromNetInt8Float32(void *, c:
> aitConvertGenerated.cc:1141: Unable to generate reloads
for:
> (insn 80 78 84 (parallel[
>             (set (reg:SI 0 %eax)
>                 (fix:SI (fix:SF (reg/v:SF 0 %eax))))
>             (clobber (mem:HI (plus:SI (reg:SI 6 %ebp)
>                         (const_int -2 [0xfffffffe])) 0))
>                         (const_int -4 [0xfffffffc])) 0))
>             (clobber (mem:SI (plus:SI (reg:SI 6 %ebp)
>                         (const_int -8 [0xfffffff8])) 0))
>             (clobber (scratch:HI))
>         ] ) 145 {fix_truncsfsi2+1} (insn_list 119 (nil))
>     (expr_list:REG_DEAD (reg/v:SF 0 %eax)
>         (expr_list:REG_UNUSED (scratch:HI)
>             (nil))))
> make[3]: *** [aitConvert.o] Error 1
> Has anybody encountered and solved the same problem?
> Burkhard
Hi Burkhard,
I had the same problem with SUSE 6.x and 7.0 and gcc 2.95.2.
Compile aitConvert.cc without optimizing on "-O0".
Thomas
Thomas Fechner - Optische Instrumente                Tel. ++49+331/7499412
                                                     Fax. ++49+331/7499436
Astrophysikalisches Institut Potsdam
An der Sternwarte 16
D-14482 Potsdam
http://www.aip.de/groups/opti/mmr/OptI.html
Debian Gnu g++ problem Burkhard W. Kolb
Prev: Re: Help for Install MEDM on Redhat6.2 Robert Soliday
Next: Re: EPICS base 3.14.0alpha1 Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Debian Gnu g++ problem Burkhard W. Kolb
Next: Help for Install MEDM on Redhat6.2 chengwx
