1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Interrupts, vectors and mv230x ioc
To: "Timo Korhonen" <[email protected]>, <[email protected]>
Date: Thu, 19 Oct 2000 14:51:17 -0600
Timo,
These routines will probably be moved out of EPICS base in the near
future into a device and or OS specific distribution. If you send your
patches I will attempt install them into the master copy.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]On Behalf Of
> Timo Korhonen
> Sent: Thursday, October 19, 2000 5:16 AM
> To: [email protected]
> Subject: Interrupts, vectors and mv230x ioc
> The issue of interrupt vector handling in our PowerPC ioc (mv2306) has been a
> little bit of an open issue for us until recently. I had to study an existing
> driver
> (written and running on a 68K cpu) that hung completely and behaved somewhat
> randomly when we tried it on our mv2306 ioc's.  The problem turned out to be
> the following:
> The driver uses functions from devLib.c to connect and disconnect routines to
> interrupt vectors: during initialization it connects to a dummy routine to check
> if the board works as expected and then, if successful, it disconnects from this
> vector and connects to the "real" irq handler.
> In vxWorks intArchLib, only a small subset of functions are implemented for
> the PPC architecture; notably, functions like intVecGet and intVecSet are not
> implemented (although they are in the symbol table and calling intVecGet for
> instance always returns zero!)
> This behaviour confused the driver, because it could not disconnect from the
> first interrupt. devDisconnectInterrupt (in devLib.c) uses intVecGet to get
> the connected handler - and gets always NULL, even if the vector was connected.
> On mv2306, the VME interrupts come through the interface chip (Tundra Universe)
> to a single handler which then dispatches the installed handlers based on the
> vector table information.
> The vectors are stored in linked lists by the interrupt controller driver. I
> wrote a small set of functions with which it is possible to get the
> equivalent (I guess....) behaviour to a 68K cpu.
> I also have modifications to make the devLib and veclist work.
> However, I have a few open questions:
> 1. The mv2306 structure permits having multiple handlers attached to the same
> vector. However, this causes problems for devDisconnectInterrupt (if the
> same routine is attached several times with different parameters, there is
> no way to tell which one to disconnect.)
> Allowing only one routine per vector (like in 68K) should be ok?
> 2. The code in veclist.c makes a check (cISRTest) where it tries to match the
> handler attached to a pointer to a C routine. For those architectures where this
> is imported, the call to intConnect constructs a handler from the passed
> function; in our ioc, a VOIDFUNCPTR and an int  are just put into a linked
> list of handlers. In my patch I do the following: I look for a symbol at the
> address
> and if a symbol is found, I assume that is a C funtion.  I believe this is a
> reasonable assumption?
> The generic VME irq handler (in universe.c) calls the user handler like this:
>          currHandler->vec (currHandler->arg);
> which to me looks pretty much like assuming a C routine.
> 3. The list of unexpected interrupt handlers is not very relevant in the case of
> mv2306, because the Universe interrupt handler checks the vector table and
> complains if the interrupt handler entry is NULL.
> It is not necessary to have a handler attached to unused vectors. This is just
> cosmetics, but in the patches I remove the default vxWorks handler stub
> definitions from the table, to avoid confusing error messages during startup.
> 4. I am not sure if this applies to other than mv2300 series ioc. Because of
> this, I used #ifdef MV2300 in the patches.
> 5. Could the experts help me to sort out the patches so that this could go into
> the next release (if they are still relevant)?
> I do not attach any code here but I will send it to whoever wants to help (Marty
> Kraimer?).
> Timo Korhonen/SLS
> Timo Korhonen  PSI (Paul Scherrer Institut), SLS
>                CH-5232 Villigen PSI
>                tel + 41- 56 3103262  fax + 41 - 56 310 3151
> e-mail:        [email protected]
Interrupts, vectors and mv230x ioc Timo Korhonen
Prev: Interrupts, vectors and mv230x ioc Timo Korhonen
Next: Re: Interrupts, vectors and mv230x ioc Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
