1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Performance of portable CA server ?
To: [email protected]
Date: Thu, 05 Oct 2000 12:46:35 +0200
Now I found the answer why the cas-server is that slow. The Problem is
that the cas-server is working only if called by
fileDescriptorManager.process(). This is called by a Timer. If I call
the fd-manager all 50ms all sync reads are 70 times more slow as a read
from a IOC variable. If I call it all 5 ms this factor is 14 times!
That means on a more sophisticated operating system as vxWorx and a
processor involved in more than answer epics requests it will be
impossible to achieve the same response times.
Bernhard Kuner
RE: Performance of portable CA server ? Jeff Hill
Prev: Re: Performance of portable CA server ? Bernhard Kuner
Next: Let's use the STL! [Was: about the abstractData.h] Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Performance of portable CA server ? Jeff Hill
