1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: intConnect vs ipmIntConnect vs devConnectInterrupt
To: Bill Brown <[email protected]>
Cc: Epics Tech-Talk <[email protected]>
Date: Fri, 29 Sep 2000 11:14:09 -0500
Bill Brown wrote:
> Is there any reason why ipmIntConnect() couldn't call devConnectInterupt()
> instead, thereby simplifying debugging and perhaps book keeping?
When I originally wrote the IPAC support layer for Gemini & UKIRT one of
the requirements was that it could be used independent of EPICS.  This is
why my carrier drivers don't use the facilities of devLib such as
devConnectInterupt() but call the vxWorks routines directly, although
there's no fundamental reason why they couldn't.
I'm now in two minds about this, but on balence it probably ought to
happen.  The results then become useless to anyone outside of the EPICS
consortium, but I'm not sure if there are many of those left now (although
I did change the licensing not long ago to use the GNU LGPL when
approached by someone from outside).  The advantage of switching is that
from EPICS R3.14 onwards a VMEbus carrier driver that uses devLib can run
on any OS that devLib supports.
There is one alternative that I suggest you might look at though which
avoids having to change the carrier drivers - if devLib provides a
function that you can call to get a free vector number, you could use this
in your startup script to provide the vector number argument to your
module initialization function.  In many ways I prefer this; its much
better to request a free vector number than the "try this one to see if
it's available" approach - the former only fails when there are no free
vectors left.  If devLib doesn't yet provide such a function then perhaps
it should [don't ask Jeff to write it for you though, he's very busy
working on CA for 3.14].
> I also see that drvIpMv162.c doesn't seem to support this entry point.
> Does this mean that IP-generated interrupts cannot be supported when
> using the mv162 (or '172?) as a carrier?
No, the command table for the mv162/172 carrier has a NULL in the
(*intConnect)() position, but this tells ipmIntConnect() to call
intConnect() directly.  It doesn't mean ipmIntConnect() is not supported.
When you're writing IPAC module drivers you should *always* use the
ipmIntConnect() function or you'll no longer be portable between carrier
boards.
- Andrew
Every great idea appears crazy to start with.
intConnect vs ipmIntConnect vs devConnectInterrupt Bill Brown
Prev: intConnect vs ipmIntConnect vs devConnectInterrupt Bill Brown
Next: PowerPC Users: struct timespec problems Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: intConnect vs ipmIntConnect vs devConnectInterrupt Bernd Schoeneburg
