1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS support for IP-DeviceNet Scanner?
To: "Leng Yongbin" <[email protected]>, <[email protected]>
Date: Fri, 15 Sep 2000 07:35:17 -0700
At 03:56 PM 9/15/00 +0800, Leng Yongbin wrote:
>Hello everyone. Has anyone developed device driver
>and EPICS support for SBS IP-DeviceNet master?
>Or can anyone give me some help about it?
>We choose DeviceNet as fieldbus of our control system,
>using IP-DeviceNet as scanner and AB1794 as slave.
>So we need a driver now.
>I have developed a sample device driver for IP-DeviceNet
>based on SBS example code. I can control HURON DeviceNet
>Slave Emulator using this driver. But when I try to connect
>AB1794-ADN there are some problem. Poll IO connection can
>be established but there are no any data exchange between
>them. So after several seconds this connection was deleted.
>I am confused about it and need someone's help
>All replies will be appreciated.
>Leng Yongbin
>ll
We are at a similar point.  I _think_ the problem we are having
is due to the way the A-B scanner is configured.  Unfortunately,
I only had a very brief shot at the hardware back in January; then
it had to be shipped to our magnet vendor for testing.  It's
alleged that it will be available again around the end of the
month.
Anywho - based on my insufficent understanding of how it ought
to work, The sacnner your connected to has to be listed in it's
own scan list or you can't "see" any of the A-B hardware connected
to it from the DeviceNET side.
I'm probably not being too helpful here.  I haven't looked at
this since January so I've probably even got all the buzzwords
mixed up.  I wish you luck, and I'll probably be around asking for
help in a month or so.
-bill
EPICS support for IP-DeviceNet Scanner? Leng Yongbin
Prev: EPICS support for IP-DeviceNet Scanner? Leng Yongbin
Next: driver for IP-Octal opto422 Lifang Zheng
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
