1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: How to build EPICS3.13.1 for PPC?
To: "shen guobao" <[email protected]>, <[email protected]>
Date: Tue, 1 Aug 2000 09:29:59 -0600
Hello,
You will need EPICS R3.13.3 if you wish to build against the SENS IP kernel which
is present in Tornado II because WRS header files have defined a macro with
the same name as one of the fields in the CA data structures.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]On Behalf Of shen
> guobao
> Sent: Tuesday, August 01, 2000 2:46 AM
> To: [email protected]
> Subject: How to build EPICS3.13.1 for PPC?
> Hello,
> I use EPICS3.13.1, vxWorks5.3.1(PPC2303). My host is Sun/Solaris2.7,
> target is MV2302 board(PPC603).
> Now I want to build base for PPC, I have modified some files.
> In CONFIG_SITE_ENV:
> I set 'CROSS_COMPILER_TARGET_ARCHS=mv2303'
> And I create the CONFIG.Vx.mv2303:
> # $Id: CONFIG.Vx.mv2303,v 1.1 1998/06/04 19:15:13 wlupton Exp $
> # This file is maintained by the EPICS community.
> # Vx GNU cross compiler suffix
> CMPLR_SUFFIX = ppc
> # For Vx directories of form:
> #   $(VX_DIR)/$(HOST_ARCH).$(ARCH_CLASS)/bin
> ARCH_CLASS = ppc
> # Architecture specific build flags (TRUE=1 via LBL; needed in
> camessage.c)
> ARCH_DEP_CFLAGS = -fno-for-scope -DCPU_FAMILY=PPC -DCPU=PPC603
> -D_GNU_TOOL -DTRUE=1
> But when I use gnumake in the epics/base/ , it gives the following
> errors:
> /ssrf/project/master/wind/T1.0.1/host/sun4-solaris2/bin/ccppc
> -B/ssrf/project/master/wind/T1.0.1/host/sun4-solaris2/lib/gcc-lib/
> -nostdinc -ansi
>  -pedantic -O2 -fstrength-reduce  -Wall   -fno-for-scope
>  -D_GNU_TOOL -DTRUE=1  -DvxWorks -DV5_vxWorks -fno-builtin  -I. -I..
> -I../../../include -I../../../include/os/vxWorks
> -I/ssrf/project/master/wind/T1.0.1/target/h   -c  ../iocinf.c
> In file included from ../iocinf.h:212,
>                  from ../iocinf.c:151:
> ../caProto.h:241: syntax error before `.'
> ../iocinf.c:146: warning: `sccsId' defined but not used
> ../os_depen.h:36: warning: `os_depenhSccsId' defined but not used
> gmake[3]: *** [iocinf.o] Error 1
> gmake[3]: Leaving directory
> `/ssrf/project/master/epics/R3.13.1/base/src/ca/O.mv2303'
> gmake[2]: *** [buildInstall.mv2303] Error 2
> gmake[2]: Leaving directory
> `/ssrf/project/master/epics/R3.13.1/base/src/ca'
> gmake[1]: *** [ca.buildInstall] Error 2
> gmake[1]: Leaving directory
> `/ssrf/project/master/epics/R3.13.1/base/src'
> gmake: *** [src.buildInstall] Error 2
> How can I do?
> Best Regards,
> guobao shen
How to build EPICS3.13.1 for PPC? shen guobao
Prev: How to build EPICS3.13.1 for PPC? shen guobao
Next: RFC: Graphical Database Editor Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
