1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Building base EPICS 3.13.2 under KAI C++ compiler
To: Jeff Hill <[email protected]>, [email protected]
Date: Thu, 06 Jul 2000 15:25:44 -0500
Jeff, thanks very much. That was it !
Vladimir
----- Original Message -----
To: "Vladimir Sirotenko" <[email protected]>; <[email protected]>
Sent: Thursday, July 06, 2000 3:22 PM
Subject: RE: Building base EPICS 3.13.2 under KAI C++ compiler
> Vladimir,
> If your compiler does not define one of the following
> ( in base/src/ca/net_convert.h ) then you will need to
> define an appropriate macro on the C compiler command
> line using your version of the build system configuration
> files. You will probably need "- D_M_IX86" or "-D_X86_".
> Jeff
> #if defined(VAX)
> # define CA_FLOAT_MIT
> # define CA_LITTLE_ENDIAN
> #elif defined(_M_IX86) || defined(_X86_)
> # define CA_FLOAT_IEEE
> #elif (defined(__ALPHA) && defined(VMS) || defined(__alpha)) &&
defined(VMS)
> #elif (defined(__ALPHA) && defined(UNIX) || defined(__alpha)) &&
defined(UNIX)
> #else
> # define CA_BIG_ENDIAN
> #endif
> > -----Original Message-----
> > From: Vladimir Sirotenko [mailto:[email protected]]
> > Sent: Thursday, July 06, 2000 1:58 PM
> > To: [email protected]
> > Subject: Building base EPICS 3.13.2 under KAI C++ compiler
> > Hi,
> > I am building base EPICS (host) under KAI compiler KCC on Linux box
> > and build  was ok with several warnings.
> > Unfortunately, CA client does not work.
> > When I run ca_test (with excas running)  I got the following:
> > <d0lxbld4> ca_test janet
> > CAC: post_msg(): Corrupt cmd in UDP msg d00
> > ../iocinf.c: bad UDP msg from d0lxbld4.fnal.gov:4526
> > err resp  was "User specified timeout on IO operation expired"
> > Not Found janet
> > At the same time with native gcc base EPICS build everything is ok on
the
> > same machine (!)
> > and ca_test works ok and produces the right dump.
> > We are using :
> > Red Hat Linux Release 5.2.1
> > Kernel 2.2.12-20f1smp on an i686
> > KCC, v3_3f_1
> > gcc 2.7.2.3.f.1
> > Any hints where to look?
> > Vladimir
RE: Building base EPICS 3.13.2 under KAI C++ compiler Jeff Hill
Prev: RE: Building base EPICS 3.13.2 under KAI C++ compiler Jeff Hill
Next: memory leak - 7/10/00 cpu used is 74.7% normally 61-62% luchini
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
