I am building base EPICS (host) under KAI compiler KCC on Linux box
and build was ok with several warnings.
Unfortunately, CA client does not work.
When I run ca_test (with excas running) I got the following:
<d0lxbld4> ca_test janet
CAC: post_msg(): Corrupt cmd in UDP msg d00
../iocinf.c: bad UDP msg from d0lxbld4.fnal.gov:4526
err resp was "User specified timeout on IO operation expired"
Not Found janet
At the same time with native gcc base EPICS build everything is ok on the
same machine (!)
and ca_test works ok and produces the right dump.
We are using :
Red Hat Linux Release 5.2.1
Kernel 2.2.12-20f1smp on an i686
KCC, v3_3f_1
gcc 2.7.2.3.f.1
Any hints where to look?
Vladimir
- Re: Building base EPICS 3.13.2 under KAI C++ compiler Kay Kasemir
- RE: Building base EPICS 3.13.2 under KAI C++ compiler Jeff Hill
RE: Problems with the CA lib under LynxOS with R3.13.2 Jeff Hill
<2000>
<2000>
