1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PID records
To: Jim Thomas <[email protected]>
Cc: [email protected]
Date: Fri, 30 Jun 2000 13:42:46 -0500
Jim Thomas wrote:
> >>>>> "Marty" == Marty Kraimer <[email protected]> writes:
>  Marty> If you look at the new APS epics page, you will see that a serious
>  Marty> effort is being made to have better support for "unbundled"
>  Marty> products.
>  Marty> It allows each unbundled products to evolve at its own rate rather
>  Marty> than waiting for new releases of base.
> But what then happens to the Record Reference manual?  Already there are
> records "in" base like aai/aao which are not in the manual.  Does the
> manual split into the "common" chapters in base and each record has its own
> chapter separately?  That makes it harder to index but may be the only way?
> Jim
Documentation for unbundled products should come with the product. I don't see
any other reasonable solution.
For example look at
http://www.aps.anl.gov/asd/people/mrk/epics/modules/bus/allenBradley/
Which is reached by starting at
http://www.aps.anl.gov/epics/
and going to
http://www.aps.anl.gov/epics/modules/bus.php
Marty Kraimer
Interrupts Dmitrovskiy Alexei
PID records Benjamin Franksen
Re: PID records Marty Kraimer
Re: PID records Jim Thomas
Prev: Re: PID records Jim Thomas
Next: Interrupts Dmitrovskiy Alexei
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
