1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: mbbo record
To: "F. Gougnaud" <[email protected]>, <[email protected]>
Cc: "EPICS Tech-Talk" <[email protected]>
Date: Thu, 15 Jun 2000 15:35:03 -0400
The mmbo record would work just like a longout when there were no strings or
values defined for the states (and before the long out existed). It sounds
as though someone 'fixed' this feature by having the control range returned
as the maximum number of states. Even worse, if dbpf cannot put something
greater than 15, than it is done at the database library layer. If you
recalled this working, it was not your imagination. However, it sounds like
it would be best to now use mbboDirect or Longout.
    Bob
mbbo record F. Gougnaud
Re: mbbo record Ralph . Lange
Prev: RE: Proposed R3.13.3 Jeff Hill
Next: XYCOM560 Jack
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: mbbo record Ralph . Lange
Next: Re: PID records [was Re: Proposed R3.13.3] Brian Bevins
