1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: mv172 boot error?
To: "Garrett D. Rinehart" <[email protected]>
Cc: [email protected]
Date: Wed, 31 May 2000 09:41:01 -0500
Garett,
"Garrett D. Rinehart" wrote:
> I get this "Error: PROXY with seqential addr disabled." when I boot my mv172.
> The boot is eventually successful, but I was wondering if there was something I
> should do to clear up this error.
This happens if you boot a vxWorks target that has been built with PROXY
arpd stuff but don't give it a backplane IP address in the boot parameters
- it's not necessarily an error, but WRS assume that if you've included
the PROXY stuff in the boot image you should be using it and print the
error if you aren't.  For EPICS purposes it's likely that you'll want to
be able to use the same vxWorks boot image for both kinds of systems, so I
disable the error message for our BSPs here at APS by commenting out the
relevent printf() in target/src/config/usrNetwork.c
- Andrew
Complexity comes for free, Simplicity you have to work for.
mv172 boot error? Garrett D. Rinehart
Prev: mv172 boot error? Garrett D. Rinehart
Next: PID Record Leonard J. Reder
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
