1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Power PC processor
To: Robert Willson <[email protected]>
Cc: [email protected]
Date: Tue, 09 May 2000 10:51:55 -0500
Robert Willson wrote:
> Does the EPICS platform support PPC IOCs at this time?  I am using an
> MVME2306 processor.
Yes, if you run R3.13.2.  When you install Tornado 1.0.1 make sure you do
*not* have the SENS TCP/IP stack included - this has a separate
installation key in the Tornado installer although it's not made obvious
so most people include it.  If you have problems building parts of Channel
Access ('m_type' is generally mentioned) then you included SENS and you'll
have to re-do the installation to remove it.
If you only have Tornado 2.0 you get no choice about using SENS.  There is
a workaround, although there may still be questions about reliability (can
anyone else confirm or deny the existence of any problems?) - ask Janet
Anderson <[email protected]> for the changes necessary.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Power PC processor Robert Willson
Prev: Power PC processor Robert Willson
Next: E500 motor controller Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
