1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: aao record behaviour
To: Korhonen Timo <[email protected]>
Cc: [email protected]
Date: Fri, 28 Apr 2000 09:45:49 -0500
At aps we have not used the aai or aao records. Thus I fear making changes. If
You and Eric can agree on changes (starting with the 3.13.2 version) I will put
the new version in the next release.
Here is another problem for  aai and aao.
The init_record looks like
    if (pass==0){
        if(paai->nelm<=0) paai->nelm=1;
        return(0);
And then it waits for device support to allocate space for the array during pass
= 1. This can lead to severe problems since storage MUST be allocated during
pass 0. If another record has a link to the array and this record gets
initialized before thye array record bad things will happen. If you and Eric
decide to fix the problem I have an idea that may work. It dose mean, however,
that associate device support also needs to be modified.
Marty Kraimer
Korhonen Timo wrote:
> Hi all,
> I wanted to use the aao (array analog output) record and noticed a
> problem: when I put an array to the channel that is shorter than
> the original NELM value, the NELM gets set to the number of put
> elements.
> A search in the tech-talk archive resulted in the following hit
> (from April, 1996!):
> >From: "Eric Bjorklund, NPSM" <[email protected]>
> >Date: Thu, 11 Apr 1996 12:19:54 -0600 (MDT)
> >Subject: Possible Problem with aao Record
> >Message-Id: <[email protected]>
> > We have discovered what may be possible bug with the aao record.  The
> > problem appears to be in the "put_array_info" routine, which stores the
> > number of points to write in the NELM field of the record.  The problem
> > with this that if you write less than NELM points to the aao record,
> > any further connections to this record get the new, lower, value of NELM
> > (through "cvt_dbaddr" or "get_array_info") and are no longer able to
> > write as many points as the record originally specified.
> > My questions are:
> > o Shouldn't "put_array_info" be updating the NORD field instead of the
> >   NELM field? (if so, it means we should probably change the code in
> >   devAaoCamac.c as well).
> > o What is the correct value, NELM (the capacity of the record) or NORD
> >   (the number of points actually written) to return from "cvt_dbaddr"
> >   and "get_array_info"?
> > o (and, BTW...  shouldn't SIOL be defined as an OUTLINK on an aao
> >   record?)
> >                                        Eric Bjorklund
> >                                        AOT-6 (LANSCE Operations)
> >                                        LANL ([email protected])
> I tried the changes that Eric proposes and then the aao seemed to work
> as I expected.
> Have I missed something, is there a real reason for that behaviour or
> have the fixes been left out from the distribution (I am using 3.13.2)
> by mistake?
> Timo
> Timo Korhonen  PSI (Paul Scherrer Institut), SLS
>                CH-5232 Villigen PSI
>                tel + 41- 56 3103262  fax + 41 - 56 310 3151
> e-mail:        [email protected]
Re: aao record behaviour Korhonen Timo
Prev: aao record behaviour Korhonen Timo
Next: Re: aao record behaviour Korhonen Timo
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
